Looking for 2000+ or 3000+ watts @ 2 ohm
mysilver02alty
Oh, i fcuked up and bought the wrong amp for my planned setup. Im not sure if im going to go with 2 12 inch IDmax'/RF T series or 2 REXXX's(12's or 15's if i can get a small enough senclosure that will sound good).
So basically, if i go with the IDMax's or RF T's i need a 2000 - 2500 rms or so watt amplifier. The REXXX's i'll need an amp with like 3500 watts +.
Needs to be at 2 ohm. Im not really wanting to spend more than 400 for the 2000 watt amp and like 550 or so for the 3500 - 4000 watt amp because it would be cheaper to just get 2 amps.
Any suggestions would be appreciated.
im my opinion you wont find a good amp with that kind of power for that price, you can get a cheap amp but the power wont be true power and there will probably be a lot of distortion
I doubt you will find one, but if you can get your hands on a a T3-1000D amp from ultimate-sound it would be the perfect match. It makes full power at 2ohms and produces around 2700watts rms.
Its a canadian compagny that has their stuff made over seas like everyone else. The amp is rated at 1000watts, not sure why its rated so low, the manual says other wise and so does PAS mag, a magasine that benched it.
Its a beast:
Seems like a great budget amp:
http://www.ultimate-sound.com/template/default/pdfs/T3/T3TechSpec1000.pdf
What vc are the subwoofers? The amps that come in mind that does that kind of power are. Rockford Fosgate T4K, Kicker ZX2500.1. Those Memphis Mojo's is one hell of a deal!
Edit: Just read you won't spend 400$ on a 2kwrms amp and 550$ on a 3500-4000wrms amp. GL cause I do not think you'll find a quality amp around that price for that power @ 2ohms.
Im probably just gonna get 2 amps @ 1200 - 1500 w each when i find the right subs. Thanks for all the suggestions.
mysilver02alty
mysilver02alty
Florida
quakerroatmeal
