looking for 2 12 or 2 15s
These are not bad subs. I almost bought these awhile ago but instead went another route. They are basically the American Bass TNT in a steal stamped basket instead of the cast aluminum. You don't want the 1522 though your gonna want the 1544, the dual 4 ohm vc, so it can be wired to 2 ohm each sub then when wiring the 2 subs together for a final impedance of 1ohm load at the amp.
SORRY I messed up..
okay thanks alot for the info what ima do is get that ground shaker enclosure and get 2 15s instead of run ima,wire them to 2 ohms and makecsuee they are 400 rms which equals to that 1 ohm 800watts
Sent from my SM-G935T using Tapatalk
yeah sorry I had wrong ohm subs listed, I've been shopping for amps myself and looking at amps they aren't 1ohm stable (to many #'s in my head) so what subs u think u get? ab, sundown, jl, sq (they are cheap just not best sounding) just don't want u to get better subs than amp can push, that's y we tried to talk u into 1 sub so u have plenty of power for it.. of course if u get nicer subs that sound good but not stupid loud u can sell amp and get bigger one later I guess..
Running @ 2ohms mono isnt too shabby in itself( My CRV gets down pretty good @2 ohms mono)..Get a great amp with some head room @ 1 ohm,and a single 15 - DVC4 ohm run @ 2 ohm for the time being,and grabb up another sub and build a dual ported chamber...Subs up ,port rear in that SUV, and she can sound fantastic @ 1 ohm load. for a pair, you may even try 4-12s,or squeeze 4-15s in there or an 18,or a pair walled,8-10s even??You have some room to play with as well as to fill.Need get your electrical done right.Never rush into a complete system install,take your time and BUILD it the WAY YOU WANT,and enjoy it research , go to some shows and look at and listen to several different systems ..You can always add to it as time goes on,and buying good quality gear that last, makes it worth while for your money spent.
would it be a good match with my amp?
---------- Post added at 10:54 PM ---------- Previous post was at 10:54 PM ----------
5/8 wood meh.
Sent from my 2PYB2 using Tapatalk
5/8 bad?
5/8 bad?
Yes you want 3/4 def many double baffle depending on weight of subs.
so don't buy?
---------- Post added at 10:59 PM ---------- Previous post was at 10:58 PM ----------
it's 93 pounds with the subs and Enclosure
yeah he just pm me back about that box I told him most of those boxes port is only like 11" long (I asked buyers on amazon) and after u subtract all disp it's comes out to like 55hz (sometimes) port need to be twice that or more to tune close to right
yahhhyahhh
yahhhyahhh
Miami, Florida
BOOMINGRANDPA
