looking for 2 12 or 2 15s
YEAH I agree with other reply about 1 sub.. u could do 1 sundown d2 12 ported with 800rms would be better than what u have.. just keep n mind your amp doesn't have subsonic filter so u need to be careful with port tuning (get custom box tuned below 35hz) or get ss f mods which just plug into rcas to keep some of the freqs lower than your port tuning away from sub.. since u hve suv u could get 1 15 ported (box would be very large) almost all prefab ported boxes aren't big enough or tuned correctly especially the dual 12 boxes I couldn't find 1 that was even close, even my single box port is to small) that should be tons louder that what u have with 800rms
what about A Ground shaker box?
Sent from my SM-G935T using Tapatalk
It will definitely be better than the what ya got for sure. You could probably find someone locally that could build you a custom box for around that price that would be tuned for the sub/subs you chose.
I stay in Fort Lauderdale do you know of any places ?
I just checked the dual 12 box really fast and I don't know if it's tuned quite as good as it says each sub would have about 1.5 cf ad probably (12" box) so I'd have to know how big the port is and length, all the prefab dual slot ported boxes I checked were tuned to like 55hz,, if something says 32hz after u subtract sub displacement it's normally really like 38hz but that's as good as it gets with prefab., those round ports make it easier to get correct air space cause port doesn't take up .5 cf.. well I'd say with your amp u should do 1 15 or maybe 2 lower end 12's idk about 2 15's not saying it won't work..
Actually yeah that's probably good (i didn't run the #'s) if it's really got 5cf then yeah that's probably tuned right., all the prefab dual slot ported boxes I checked were tuned to like 55hz,, if something says 32hz after u subtract sub displacement it's normally really like 35hz but that's as good as it gets with prefab., those round ports make it easier to get correct air space cause port doesn't take up .5 cf.. so that would probably do well, i'll run #'s real fast
thanks bro let me know and also sum 15' subs that would really make it pound..
[quote name='yahhhyahhh']I stay in Fort Lauderdale do you know of any places ?
Sent from my SM-G935T using Tapatalk[/QUOTE]
Just get one built and shipped. @Flastrongman ; could. He is across the way. Dave is his name. Fellow nyer. With the trip for a fine box
Sent from my 2PYB2 using Tapatalk
well I'm kinda shocked but if the size listed is correct and IF those are 4" ports I think after u subtract sub displacement it would be tuned to about 34hz.. so it's really good for prefab.. as far as subs I was gonna recommend 2 sundown lcs 12 (with your amp) but they don't even come in 15's yet.. see if u go with 1 15 u can get a well bigger one to go with the 800rms u have if u do 2 u need some lighter ones the 400 per sub will push fairly well.. i'll look but sundown e would work also SQ 200 15 would work and they on sale stupid cheap ($103 I saw other day) but as I was informed they don't sound good but if u want loud that'd do it.. i'll see if anything else in the 300-600rms range I can find.. well u can get 2 jlw0 v3 (d4) for $200 each, dc level 2 $229 or https://www.sonicelectronix.com/item_90862_American-Bass-XD1522.html if u just get 1 sub u could get the ab xfl or a fu 750 (that would be good on 800 rms or a sundown e or sa, lot smaller box and less $ for subs ) be sure if u get 2 u get d2 so u can wire to 4 ohm each or if u get 1 get d4 wire to 2ohm..
okay thanks alot for the info what ima do is get that ground shaker enclosure and get 2 15s instead of run ima,wire them to 2 ohms and makecsuee they are 400 rms which equals to that 1 ohm 800watts
[quote name='mclerico83']Just get one built and shipped. @Flastrongman ; could. He is across the way. Dave is his name. Fellow nyer. With the trip for a fine box
Sent from my 2PYB2 using Tapatalk[/QUOTE]
I think he resides in FL ...hence the partial screen name.
ima get this enclosure https://www.amazon.com/gp/aw/d/B00UKI5KPW/ref=mp_s_a_1_11?ie=UTF8&qid=1488136431&sr=8-11&pi=AC_SX236_SY340_FMwebp_QL65&keywords=groundshaker+sub+box
and put in these subs American Bass XD1522
[quote name='Boomin_tahoe']Pre fab isn't gonna sound as good as a custome enclosure. @CSCStang[/QUOTE]
I can't afford a custom but I'm not looking for sq I'm mostly looking to be heard and have it loud
yahhhyahhh
yahhhyahhh
Miami, Florida
BOOMINGRANDPA
