LOC suggestions.
since you want to run a full system off a LOC, what is the factory system consist of? you could just use a regular 4 channel LOC but if the factory system has a sub or components you'll want a LOC that does a bit more like an Audiocontrol LC6i. Personally I use an Audiocontrol LC6i or LC8i with an Audiocontrol Three.1 or Kicker KQ9, but that's just me.
I just used a PAC SOEM-T (2channel) on mine and it works great, sounds the same as when I had my aftermarket HU in. I just used a set of rca splitters and connected one set to my sub input and the other to my fronts and set the crossover points on my amp accordingly. Pac makes a 4 channel, SOEM-4. You could do the same concept, hook up splitters for you front and rear and the other set to you sub input. And it's under $30. I was going to look into the Audio Control as well, but forgot I had this one still laying around (I never used it before) and am really impressed with the sq so far.
pelekeliko
pelekeliko
East bay, CA
fasfocus00
