LM Audio 3200.1
wilson_gau
LM Audio 3200.1
Model : LM Audio - LM 3200.1D (Class D)
▪ 1 Channel Class D power amplifier ▪ 1 x 3000 watt (1 Ohm) ▪ 1 x 700 watt RMS (4 ohm) ▪ 1 x 1300 watt RMS (2 ohm) ▪ THD at 1 Watt, 4 Ohms : 0.30% ▪ THD at 1 Watt, 4 Ohms : 0.50% ▪ signal - to - Noise ratio : 100dB ▪ Frequency Response, at 1 Watt, 4 ohm : 15Hz to 150Hz (+/- 3dB) ▪ Frequency Response, at rate power, 4 Ohms : 20Hz to 250Hz (+/- 3dB) ▪ damping factor at 20Hz, 4 ohm : 400 ▪ Crossover Low Pass : 50Hz - 150Hz 24dB/Octave ▪ Crossover Subsonic (High Pass) : 15Hz - 40Hz, 24dB/Octave ▪ Bass Boost : 0 + 18dB ▪ Phase Control : 0 to 180 Derajat ▪ Input Sensitivity : 100mV to 2V ▪ Input Impedance : 10K ohm ▪ Line Output Impedance : 100 ohm ▪ Peak Current Consumption, at rated power into 1 ohm : 160 Amperes ▪ Dimensions : 20'L x 7'W x 2,36'H ▪ Fuse Rating : MFU 80A x 2
Made in Korea
Cosmetic: 8-9/10
Function: 10/10
Working good. Some little scratch, nothing big..
FYI, the little brother of this amp (LM Audio 2200.1 beat MMATS 1400.1 - I tried them on the same setup, just switched amp).
$300 shipped, no lowball
Not really looking into trade, unless you have SQ items (ie. McIntosh Amp). I will add cash on my end if you have something that interest me.
I might also interested for budget 4ch amp plus cash on your end (like PPI or Soundstream, not Boss or Power Accoustik junk).
I have 100% feedback here, caco, lxforums.com, forums.azbilliards.com, ebay, etc etc
Shipping included
Amp Photos by wilson_gau | Photobucket
Every website I can find information on this amp is from the Indonesia region and every web page has different rms ratings posted... Sounds like a sketchy amp to me op
First, it is from Indonesia, since it was my home country and I bought it there. I NEVER said its 3200k rms @ 1 ohm, other than the specs that I found. I only mention that the little brother of this amp 2200.1 beat MMATS 1400.1, and I knoe this will never do 3200 @ 1 ohm.
If you think its a sketchy amp, its up to you, but don't trash talking it on my thread, start your own thread and feel free to write all bad stuff about LM Audio. I post the gut of the amp for a reason, so some people who know more about amp than you do can appreciate it instead of just googling to find info.
My apologies Wilson I've just never come across an amp rated for 3k rms that only runs 160a fuse... And that had so many different power ratings from every site I found it on... Sure I'm not the only person who researches audio brands they have never heard of btw
Glws
wilson_gau
wilson_gau
Seattle, WA
els1989
