LM Audio 3200.1
wilson_gau
LM Audio 3200.1
Model : LM Audio - LM 3200.1D (Class D)
▪ 1 Channel Class D power amplifier ▪ 1 x 3000 watt (1 Ohm) ▪ 1 x 700 watt RMS (4 ohm) ▪ 1 x 1300 watt RMS (2 ohm) ▪ THD at 1 Watt, 4 Ohms : 0.30% ▪ THD at 1 Watt, 4 Ohms : 0.50% ▪ signal - to - Noise ratio : 100dB ▪ Frequency Response, at 1 Watt, 4 ohm : 15Hz to 150Hz (+/- 3dB) ▪ Frequency Response, at rate power, 4 Ohms : 20Hz to 250Hz (+/- 3dB) ▪ damping factor at 20Hz, 4 ohm : 400 ▪ Crossover Low Pass : 50Hz - 150Hz 24dB/Octave ▪ Crossover Subsonic (High Pass) : 15Hz - 40Hz, 24dB/Octave ▪ Bass Boost : 0 + 18dB ▪ Phase Control : 0 to 180 Derajat ▪ Input Sensitivity : 100mV to 2V ▪ Input Impedance : 10K ohm ▪ Line Output Impedance : 100 ohm ▪ Peak Current Consumption, at rated power into 1 ohm : 160 Amperes ▪ Dimensions : 20'L x 7'W x 2,36'H ▪ Fuse Rating : MFU 80A x 2
Made in Korea
Cosmetic: 8-9/10
Function: 10/10
Working good. Some little scratch, nothing big..
FYI, the little brother of this amp (LM Audio 2200.1 beat MMATS 1400.1 - I tried them on the same setup, just switched amp).
$300 shipped, no lowball
Not really looking into trade, unless you have SQ items (ie. McIntosh Amp). I will add cash on my end if you have something that interest me.
I might also interested for budget 4ch amp plus cash on your end (like PPI or Soundstream, not Boss or Power Accoustik junk).
I have 100% feedback here, caco, lxforums.com, forums.azbilliards.com, ebay, etc etc
Shipping included
Amp Photos by wilson_gau | Photobucket
Alumapro alchemy rx 12s mint condition sinvle 4ohm 500rms
Item(s) for Sale: LM Audio 3200.1
Made in Korea
Cosmetic: 8-9/10
Function: 10/10
Shipping included
its purdy ... ever have it on the bench? im so not familiar with it...
Thanks, don't have access to bench, so never bench tested it yet.
Nope, sorry, not looking for sub now.
This the one been up on caco?
Yes, I was trying to sell it on CACO, but haven't sold it (partially I forget to bump it up every now and then), also want to see if there is any interest here.
Gold hifonics eros? Gen 8 I believe? Ads power plate 6.25 or ads pq8.2?
Then I seen this michaellane
wilson_gau
wilson_gau
Seattle, WA
els1989
