LM Audio 3200.1
Model : LM Audio - LM 3200.1D (Class D)
▪ 1 Channel Class D power amplifier ▪ 1 x 3000 watt (1 Ohm) ▪ 1 x 700 watt RMS (4 ohm) ▪ 1 x 1300 watt RMS (2 ohm) ▪ THD at 1 Watt, 4 Ohms : 0.30% ▪ THD at 1 Watt, 4 Ohms : 0.50% ▪ signal - to - Noise ratio : 100dB ▪ Frequency Response, at 1 Watt, 4 ohm : 15Hz to 150Hz (+/- 3dB) ▪ Frequency Response, at rate power, 4 Ohms : 20Hz to 250Hz (+/- 3dB) ▪ damping factor at 20Hz, 4 ohm : 400 ▪ Crossover Low Pass : 50Hz - 150Hz 24dB/Octave ▪ Crossover Subsonic (High Pass) : 15Hz - 40Hz, 24dB/Octave ▪ Bass Boost : 0 + 18dB ▪ Phase Control : 0 to 180 Derajat ▪ Input Sensitivity : 100mV to 2V ▪ Input Impedance : 10K ohm ▪ Line Output Impedance : 100 ohm ▪ Peak Current Consumption, at rated power into 1 ohm : 160 Amperes ▪ Dimensions : 20'L x 7'W x 2,36'H ▪ Fuse Rating : MFU 80A x 2
Made in Korea
Cosmetic: 8-9/10
Function: 10/10
Working good. Some little scratch, nothing big..
FYI, the little brother of this amp (LM Audio 2200.1 beat MMATS 1400.1 - I tried them on the same setup, just switched amp).
$300 shipped, no lowball
Not really looking into trade, unless you have SQ items (ie. McIntosh Amp). I will add cash on my end if you have something that interest me.
I might also interested for budget 4ch amp plus cash on your end (like PPI or Soundstream, not Boss or Power Accoustik junk).
I have 100% feedback here, caco, lxforums.com, forums.azbilliards.com, ebay, etc etc
Shipping included
Amp Photos by wilson_gau | Photobucket
LM Audio 3200.1
Made in Korea
Cosmetic: 8-9/10
Function: 10/10
Shipping included
