little sub help needed
jaygeorge1979
alright i think i found a subwoofer i might want to use for a little 2.1 setup i am building...i am going to do this project for the mains:
http://www.zaphaudio.com/audio-speaker18.html
and for the sub i want to use:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-480
it is the dayton DVC...it says that all specs are with the voice coils wired in parallel, and it says nominal impedence is 8 ohms so im guessing that means two 4 ohm voice coils, but the plate amp i want to get is 70 watts RMS @ 4 ohms so could i just use one voice coil in this case? how would this affect sound or power?
by the way the plate amp is this:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-784
jaygeorge1979
jaygeorge1979
Corpus Christi
jaygeorge1979
michigan born
    May 14, 2026
michigan born
    May 14, 2026
