Little sa-8's made me proud.
inteva6184
pa
I was letting the little guys rip pretty good and all the sudden I heard what I thought was a sub letting loose. I figured that ***** but at least I will get to try my hand in reconing. I look back and to my surprise I see chuncks of plastic all over. Apparently a tupperware container rattled off my seat in between my door and port. I know its nothing compared to some of you guys but the shrapnel those little 8's made made me proud.
[/img]
That's not Tupperware. Tupperware is indestructible.
I knew for a fact someone was going to say that. Its some stack-able stuff I forget the brand. I just call all those things tupeperware sort of like how people say kleenex instead of tissue. Definitely not as thick and more brittle but I still thought it was pretty cool.
A video or didn't happen. I mean, how is someone supposed to know you didn't actually break apart some plastic container and throw it in the back rear floor and take a pic of it claiming some 8's destroyed it?
Lol, yeah was just f*cking with you.
Ha I know, I was just cracking up because I knew I was going to get called out and it was the first post.
Video is terrible and doesn't show much of anything but it's all I took with Snapchat. You can see little chunks of plastic flying out at one point.
https://youtu.be/9zYolxBJLOM
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
Yes, what Dox said. The ++ -- makes it so you don't have to shove 4 wires into 2 connections. Convenient.
200
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
671
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
692
inteva6184
inteva6184
pa
inteva6184
    May 18, 2024
    May 16, 2024
