Little Help With Setup
qwiktune
Ninja Samurai
So i have a question about my setup and how I can make it optimal. First of all I have a Pioneer avh-p6600dvd, i believe it says 2 channels x50. I have an Alpine amp powering my Sony 12s in my trunk, my question is my high end speakers. I have 2 in the front and 2 in the back, I forget the wattage, i think maybe 50 rms each. I have them plugged right into the head unit via the wiring harness but I also have a spare rockford amp [500watts i believe] that I was thinking about using for them. There is RCA front output, RCA rear output, and RCA Sub output. I have my Alpine amp in the sub output powering my subwoofers. Would I get better sound using my spare rockford amp plugged into the Front output RCAs instead of just in the wiring harness or how does that work? Would i need 2 different amps to plug the fronts in the front RCA output and a separate one for the rear 2 speakers into the rear RCA output? Anyone familiar with this head unit? I'm just a little confused, please help me out as I dont think im gettin the full potential out of my highs
Anyone? I guess generally what should I do to get optimum power my 4 high end speakers when I have a 2 channel headunit that has RCA Front Output, RCA Rear output, and RCA Sub output [assuming my subs obviously would connect to the sub output]....I hope this question is understandable lol
you will need a 2 or 4 channel amp to run you front/back speakers. You will have to run speaker wire from your amp(s) to the door panels or wherever else they are and hook them up.
qwiktune
Ninja Samurai
qwiktune
Pittsburgh
09civic
BP1Fanatic
BP1Fanatic
