line output converter help?
yeah im going to hook up a line converter to my stock hu to run a amp for 4 new door speakers.but my question is do i cut my wires and put the converter on then run the rca to amp then new speaker wire to speakers and just abandon old speaker wire or is there another way.thanks for any help
you need to get a signal to your amp which means you would need to hook up the converter to the original wires behind your stock head unit. what i would do is only use those old wires to hook up the converter and then run new speaker wire individually to each speaker directly from the amp.
x1-1/2
hook up the line out convertor to the the rear left and right speakers to get a
signal just be sure to disconnect the factory speakers
whisperingeagle
whisperingeagle
windsor va
squeak12
