Line Drivers..what is its function??
line drivers boost output voltage of rcas. say you have 2v preouts, you run that to a line driver, and the out put from there will be more (depends on the line driver in question)
I have a Fosgate t2000 amp and there is not much contorl to it from the remote. I would like to get more from a wired remote and was wondering if such item as labzar would help
no but it looks like it is a bass line driver not just a regular one.7 volt pre-out (seen higher) remote adjustments.I have an audiobling ab39t that is about the same.I had pretty good results with it.I like the fact you can control the volume as well as the Q and change freq. all from the dash.
is your audiobling and lanzar pretty much the same?
what is the exact name of that ab39t that you have, I want to look it up
tom4info
tom4info
Los Angeles, CA
helotaxi
