Line Driver
You really don't NEED a line driver.
What is your setup though?
I'm running a RF Symmetry and it does have a line driver in it (along with a crossover) which I LOVE and is rather cheap. If you want one, look that route.
if your only running 1 or 2 amps then you'll be fine.
If you add one and don't set your gains proper you can have major clipping and probably blown speakers.Or the bass will be so loud at low volumes you might drowned out the highs.
My jensen won't put out enough to power my amps probably. Im only running one amp and two subs and my jensen just wont power them. when i use my xplod deck it powers it to the fullest. So what do i need to do?
I have two audiobahn AW121T and a legacy predator amp (2400 max by 2 channel). My gain is set at 75%. The amp and subs is are working when there hooked to my jensen but they are work at the potential they should. My xplod deck pushes them to the poteneial and then some. What is the best way i should fix my situation?
I have installed a couple jensen screens and have had no problems with output from the sub channel.
Check the settings on the sub out to make sure there not set wrong.And make sure your using the sub channel and not the front/rear output.
Use the RCA that is labelled subwoofer, like the blue/white pair in this picture
p3bumpin
p3bumpin
Brier Hill, NY
p3bumpin
