Line driver question......
CarAudioNewbie9
I'm starting to hook up my system and I need some advice.....
My head unit is 4 volt preamp. My amp (MB Quart 4125) has a max voltage of 6 volts. If I install my line driver (PG TLD22) I'm guessing I won't be able to run it at 8 volts because my amp can only "handle" 6 volt max? So I would have to set my level on my line driver at 6?
The head unit only puts out that 8v rating when the volume knob is turned all the way up, way past reasonable levels of distortion. When listening normally, you won't see anywhere near that voltage. You will be fine.
CarAudioNewbie9
CarAudioNewbie9
BFE
DarkScorpion
