limited mounting depth suggestions
titanle
What 10" sub with a 5 9/16 or LESS mounting depth really pounds? My cvr's arent loud enough. Ive checked out the sundown sd1 which is 4.5" mounting depth but its also rated at 400rms like the kicker. What other subs are out there that meet these specs?
Mach 5 IXL 10.... 5.5"
Don't forget the 1" clearance for the pole vent and the fact that the surround sticks out quite a bit requiring a good amount of clearance in front as well.
Just realize that a powerful sub is going to need a good sized motor and that is going to require some depth with a conventional design. You could look at some of the slim mount subs but I wouldn't count on them getting much louder than your CVRs and they will cost more as well. Power handling does not equal output either.
What is your goal? Are you after sound quality or after SPL? That answer will help everyone direct you to which sub to buy.
In a perfect world I would like a sq sub that gets plenty loud. But I guess I would prefer sq since i got some pretty good comps, i want the subs to compliment them.
I am selling a bnib image dynamics id10v3 10" sub. Has 5.5" mounting depth and is rated at 350 watts rms. Great sounding sub but the cvr may be louder.
I would be looking for 2 if my kickers sell. I would want something at least as loud as my current setup if it has better sq
Add some polyfill to that box, i bet its not even close to rec specs
i have no idea what the box specs are. but before i loaded the subs, i sealed the inner joints and i added polyfill. I agree that its probably not close to rec. specs.
titanle
titanle
BC, Canada
titanle
