lil help please
Originally posted by blackblazer98 can anyone give me a detailed description on how to run a wire from my battery into my car through the firewall i cant figure it out. thanx
well there needs to be a hole somewhere in your firewall for the wire to go through...my car has one on each side, but yours might not. in that case, i think you just need to drill a hole big enough for the wire to fit through.
Take a bit of wire with you to the auto parts store and pick up some rubber grommets make sure you find some big enough to put the wire through. This is going to make sure the firewall doesn't eat away at you wire and cause a fire hazard.
Mike
blackblazer98
blackblazer98
IA
MikeofTulsa
