hdj20 10+ year member F*CK SONY 784 0 wisconsin May 27, 2009 #1 Im running one fi q 12" with an american bass vfl 80.1 at 1 ohm. Also have 1 3.5 farad cap in. Amp kit is the KLM 4 gauge. At higher volumes lights dim pretty bad. Whats the best upgrade I could do to help this. Click to read more...
alvitae 10+ year member CarAudio.com Elite 1,816 0 Oregon May 27, 2009 #2 1. What is your ground like? Free of paint and solid? 2. Big 3 3. Swap the capacitor out for a small audio battery, Kinetic 600 or similar. 4. Bigger alternator That"s the order I would try until the problem is gone.
nickolas_j_t 10+ year member I approve this message 1,884 0 Midwest May 27, 2009 #3 use a bigger alternator, problem solved
Ferendon 10+ year member Proabbly drukn 971 0 Fort Worth, TX May 27, 2009 #4 There are steps you can take before you take the plunge to a bigger alternator.
OP hdj20 10+ year member F*CK SONY 784 0 wisconsin May 27, 2009 Thread Starter #5 what is safe voltage before i should start worrying when cranked it goes from 13 to 14 volts back and forth?
AlterEgo99 5,000+ posts Streaming consciousness 12,918 233 Domie Homie May 27, 2009 #6 1. What is your ground like? Free of paint and solid? 2. Big 3 3. Swap the capacitor out for a small audio battery, Kinetic 600 or similar. 4. Bigger alternator That"s the order I would try until the problem is gone. Click to expand... Yup, that would be my approach too...Big 3 will probably fix it.
