Lets talk voltage please
Not that I am auguring but this is from the manual for my amp
ADJUSTING GAIN
To adjust the gain setting, turn the amplifier gains all the way down (counter-clockwise).Turn the source unit
volume up until distortion is audible and then turn it down a bit until the distortion is inaudible.This will be
about all the way up on most source units. Next, increase the amplifier gain setting until adequate volume is
achieved. Rockford Fosgate source units do not distort, so the volume can be used at maximum setting.
NOTE:Best signal to noise and dynamic range are realized with the gain at minimum. Most users find
adequate gain and volume is achieved at about halfway in the adjustment rang
This is all I ever do to set my gains. 90% of the time I don't go anywhere near full out anyway so it doesn't matter.
As far as what's safe for the amp it depends on the amp, some will go down til your car stalls from low voltage, some give up smoke below 12.5V. I'd suggest throwing another battery or bigger alternator if possible.
If you're wondering if the cap will help, charge it up, turn your amp on full tilt (or even half power) and let the amp run off of JUST the cap and tell us how long it'll run with the "reserve" on tap in that capacitor.
I hope this doesn't turn into another thread where everyone has to try to outdo each other.. There was some really good information being passed around in this thread and could potentially be very useful for a new guy doing a search on "voltage drop" or setting gains. I hope more useful information comes to light as the thread progresses
Set your gain with dmm. 1/2 way means nothing. You're probably clipping it hard and that's why your voltage is dropping.
Big caps have big ESR making them more worthless than the smaller electrolytic caps. Put the HO alt in. Seriously, set your gain properly. I guarantee if you're talking about "my gain is only halfway" you didn't set it properly and you are clipping like a gay hairdresser.
beat me to it >//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
>>SQL<<
>>SQL<<
USA
hispls
