lemans23 was just owned....horribly
did he have an amp on it b/c its only 80 watts rms ?
i wanna get one of these with a $20 10" sub and w/e else ill need?
is it possible to build one of these for $50 not including the amp if i need it?
yes he had wte the PE like 75 watt amp is
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-480
To match my friends NSB array, the plan was to make a bass array with the same
woofers 8 per tower {two towers} so the system would be four towers.
The reason for choosing this woofer and doing a bass array was;
1. It's cheap, in array form it will do very well for only $350.
2. SQ should be much better than a single monster 15" woofer trying to play
low pass 200 - 300hz, the midbass punch should be clean when 16 of them are
hitting the higher bass frequencies provided that you feed the array a monster
pro amp - hehe
3. My friend wants the eye candy of 16 8" woofers in two towers, looks mean.
I'd rather do a Koda 8" array but Adire dropped 8" woofers from their new lineup.
so what if i got this amphttp://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-784
and this sub
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-485
and then put it in a ported box how would it sound?
im just looking for a little hard bass
btw are there many other home subs or woofers i could run off this plate amp?
that would be excellent for a multimedia subwoofer
watch out for them audiophile's
**** yes now i know that //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
Especially the ones that think you need to break in your cables to get them sounding well, and you need $200 power cables //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If you ever want a laugh, a trip to rec.audio.high-end is mandatory. If CA.com is a bunch of teenagers bickering, that NG is a bunch of 35-50 year old executives bickering //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Different demographic, different vocabularies, same BS.
PV Audio
The Vision of Sound
PV Audio
Indy
PV Audio
