Lcd vs plasma.. What one to buy and why??
I have everything apart and in storage for about a week while my new Oak floors are being laid.....I hope by around the first of next week I'll be able to put everything back together....3 rooms downstairs are tore apart for the remodel job right now //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
suuuuuuuuuuuuuuuuure. what great timing.
Here is a cover shot of my LED TV's owners manual...Its photo dated today...so its mine.....most people on here know I have nothing to lie about....
Go anywhere, look at any numbers. The facts are that plasmas on average use 2-3x the power of an LCD monitor.
Which accounts for the average usage per year of ~2 incandescent light bulbs? lol Keep straining, I can't wait to see you pop a vessel in futility.... as I said, Kommiefornia isn't exactly the bastion of common sense... how much of a paycut has the average gov't worker there been forced to take to try to fix the massive screwups of their governing bodies???
The only thing you are effectively arguing is that YOU can still see it, so it must exist. Well guess what? it doesn't. I suspect this strong stance among plasma hyping people is because of the additional price of the LCD's you just don't wanna spend the extra money so you make up artifacts on the screen to justify the fact that you've bought or argued on the side of an inferior product.However ever since LCD's reached around the 5ms response time, motion blur is no longer an issue.
You "suspect" it is made up. Wow, that's a lot more concrete. lol The motion blur associated with these supposed 5ms LCDs is because even the response times listed are not realistic, either. Check out this review and you will see that actual measured response times on even high-end LCD-based sets were actually up to 10 times the stated rate by manufacturers. Not surprising... more inflated specs to impress uninformed consumers.
Oh funny, yet you argued so avidly about the dynamic contrast ratio. Funny also that this is simply a ploy by the LCD manufactures to make their TV's look better when most of the most popular Plasma makers also quote dynamic contrasts and leave static out of it. Know why? I wonder, lets think for a minute...
As for contrast ratios, I never said plasma didn't inflate theirs, too... I said they're all bullshit. Didn't I? Yes. But when you look at native contrast ratios (the only ones that do matter a whit), plasma still beats out LCD as well. This 240Hz marketing hype BS is all smokescreen to impress the uninformed... and it works. Great for the manufacturers, bad for consumers who are being duped into paying top-dollar for something that is not only useless, it can actually worsen a TVs performance on things like gaming and fast-moving source material. lol
Like I said before... many LCD owners have seen my plasma in my home and raved about it... not to mention that it rocks the house for gaming. So glad I didn't fall for the hype and buy one of those underperforming, overpriced LED-lit LCDs.
Here are the specs on my 47"
47" TruLED XVT Full 1080p HD 240Hz SPS LCD
Viewable: 46.96" diagonal
Tuner: Integrated ATSC/Clear QAM Tuner
Native Panel Resolution: 1920 x 1080 pixels
Signal Compatibility: Supports 480i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV), 1080P (FHDTV)
Colors: 1.06 Billion
Dynamic Contrast Ratio: 2 Million:1 (DCR)
Brightness: 500 cd/m2 (typical)
Response Time: 5ms
Computer Support: 640 x 480, 800 x 600, 1024 x 768, 1360 x 768, 1920 x 1080 via VGA and HDMI
Viewable Angle: 178° (horizontal and vertical)
Inputs/Outputs:
INPUTS (REAR)
HDMI with HDCP 3
RF Connector for Internal Tuner 1
Component YPbPr plus Stereo Audio: 1
S-Video: 1
Computer RGB: 1
Composite Video: 1
INPUTS (SIDE)
HDMI with HDCP 1
Composite Video: 1
USB Service & Multimedia: 1
OUTPUTS (REAR)
5.1 SPDIF Digital Optical: 1
Stereo Audio: 1
Audio:
SRS TruSurround HD™: Yes
SRS TruVolume™: Yes
Special Features:
Refresh Rate: 240Hz SPS*
Smooth Motion: Yes
LED: YES
Picture-in-Picture (PIP): Yes
Picture-outside-Picture (POP): Yes
Zero Bright Pixel Defect Guarantee: Yes
V-Chip: Yes
3D Comb Filter: Yes
3:2 or 2:2 Reverse Pull-down: Yes
ATSC with 8VSB & QAM demodulation: Yes
ATSC with MPEG-2 decoding: Yes
NTSC Video decoding via Video: Yes via RF or Composite
Progressive Scan Video: Yes, thru Component VGA or HDMI
Color Temperature: 6500K 9300K, 11000K
Color Fine Tuning: Independent Red, Green and Blue
Speakers: Built-in 15W x 2 Speakers
Panel Lamp Life (typical): 50,000 hours to half the original brightness
Power:
Voltage Range: 100~240 Vac at 50/60 Hz
Power Consumption: 120W, 1.0W standby
Dimensions and Weight:
Unit Dimensions with stand: 43.854"W x 29.669"H x 10.035"D
Unit Dimensions without stand: 43.854"W x 28.146"H x 4.067"D
Box Dimensions: 49.213"W x 35.433"H x 12.795"D
Net Weight with stand: 51.80857 lbs.
Net Weight without stand: 46.517482 lbs.
Gross Weight: 71.429688 lbs.
ballers dont buy vizios! way to go out of your way to prove your point....wait, i know.........WOW BRO! that tv is fantastic! youre so cool!!! i wanna be just like you when i grow up! ........did i do all that right?
Response Time: 5ms
Inputs/Outputs:
INPUTS (REAR)
HDMI with HDCP 3
S-Video: 1
Computer RGB: 1
Composite Video: 1
INPUTS (SIDE)
HDMI with HDCP 1
Composite Video: 1
OUTPUTS (REAR)
Stereo Audio: 1
Audio:
SRS TruVolume™: Yes
Special Features:
Smooth Motion: Yes
LED: YES
V-Chip: Yes
3D Comb Filter: Yes
Power:
.....................................................//content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif:hilariou://content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Response Time: 5ms
Inputs/Outputs:
INPUTS (REAR)
HDMI with HDCP 3
S-Video: 1
Computer RGB: 1
Composite Video: 1
INPUTS (SIDE)
HDMI with HDCP 1
Composite Video: 1
OUTPUTS (REAR)
Stereo Audio: 1
Audio:
SRS TruVolume™: Yes
Special Features:
Smooth Motion: Yes
LED: YES
V-Chip: Yes
3D Comb Filter: Yes
Power:
that's the one I plan on getting soon. At first I was pissed at the price jack of the LED tv's cause they are essentially just an LCD with a fancy back light, but that visio line is very reasonable and looks fantastic.
the point is mute, I can run a freakin 100amp load for 5 minutes and use less than 1 incandescent lightbulb in a year, but in the mean time I've just burned my house down in 5 minutes. That fact is that there is mountains of scientific research and reporting that back the decisions made in California. Does that make the decisions economically feasible? No not at all. But does something lose credibility only because its not economically feasible? Of course not. We would all have to take pay cuts to completely eradicate the nation's dependency on fossil fuel, does that mean it's not true that fossil fuel's will run out and destroy our environment in the process? of course not. The issue with Cali is in implementation of policy, not the principles on which policy are made. STFU everything you say is opinion contradicted by given evidence.
hey dipshit, here is a passage taken from that exact site
LCDs have their own 800 pound gorilla: limited Response Time, which causes motion blur. Just like Plasmas, this was a significant problem for LCDs many years ago, and we’ll demonstrate that it too is no longer an issue now. But unlike Plasmas, the LCD manufacturers have turned this into a brilliant marketing strategy, offering ever more sophisticated and enhanced motion processing and ever higher 120 Hz and 240 Hz screen refresh rates to repeatedly over-sell a solution to a problem… that is no longer a problem.
Your reading comprehension skills are amazing. But hey, you keep arguing against yourself and i won't have to.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif yes this certainly has evidence. LCD's particularly LED-Backlit are aproaching and surpassing plamsas in static contrast ratios. care to explain how, say, a game run at 75 hz like wow will run better on a 600hz sub-field drive TV than on a 120 hz interpolation?
useless features to me...most wifi adapter are there for the news and crapy apps...samsung on the other hand will soon offer blockbuster online app...and well i dont think the quality of vizio tvs is all that great..i have only seen one of their tvs thats impressive and thats there best led tv available...other than that i think they r budget tvs..wit awful warranty...i rather buy a toshiba
Nah those things are gnarly, it has bluetooth capability and A built-in wifi adapter.
yeah it was reasonable priced and seemed to show a cleaner sharpe pictuer than the others on display including the Sharp LED TV......I paid $1400 for it with a 3 year extended in house warranty....
hzsogood
**The Clean South**
hzsogood
TX/MN
bds0688
