Lanzar OPTI500x2 good amp?
madmaxz
maryland
Is this a good amp? whats the actual output? i take it its not bridgeable at 2ohms
looking for a high power bridgeable A/B less then $400
# 500 Watts x 2 RMS Power @ 4 Ohms
# 1000 Watts x 2 Max Power @ 4 Ohms
# 2000 Watts x 1 Max Power @ 4 Ohms Bridged
# 750 Watts x 2 Watts RMS Power @ 2 Ohms
# Electronic Crossover Network
# Bass Boost Circuit
# Bridgeable at 4 Ohms
# 2 Ohm Stereo Stable
Blueish in color? Opti500?
If that's what it is then it's:
250 x 2 @ 4 ohms,
500 x 2 @ 2 ohms,
1000 x 1 @ 4 ohms.
Will handle 2 ohms mono, but no benefit.
They're not as over rated on power as everyone thinks. They do about 10% more power then rated. Solid built tanks is what they are.
I have an Opti150 just because.
250 x 2 @ 4 ohms,
500 x 2 @ 2 ohms,
1000 x 1 @ 4 ohms.
No, it's an Opti500x2. New Optidrive, big and silverish/chome.
I have one, great amp. Lots of power. 4ohm bridged mono only.
Thats it! thanks! looks like this will be my new amp. my Rockford t5002 took a dump today //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i did torture it for 3 years, not bad fora referb. oh well it was either get another t5002 for $200 or a t8002 for $375 or this lanzar for $250.. hope i made the right choice! 1300w is perfect for my 2 idq12s on the way.
another question the t5002 still puts out to the subs its just totally distorted sounds horrible. ive never had a amp do that they either stop working all together or not any ideas?
would it be better to get dual 2ohm IDQ12s and run 750x2 @ 2ohms each or get dual 4 ohms and run it bridged at 4 ohms?
other options are but i doubt any would put out any power close to the lanzar
HiFonics ZXi1308
Autotek AT1500
Cadence ZRS-3002 (way over budget)
Cool. I lost intrest after Laznar sold back @ '99.
I think it was 96-97, but the Opti's came from Zed until '03 although they claim to have quit building them around '00.
I just bought a Opti4x400d -- just looking for some garage time, gotta do a brake job too //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
how about the lanzar OPTI600x2HC is this a newer model? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?Source=googlebase&ProductID=16461
another amp option is the cadence ZRS-3002 and is less then $400 new also
# 4 ohm RMS Power: 2 x 300 Watts
# 2 ohm RMS Power: 2 x 600 Watts
# 4 ohm Mono RMS Power: 1 x 1200 Watts
OPTI600x2HC
# 2x300 Watts RMS at 4 Ohms
# 2x500 Watts RMS at 2 Ohms
# 2x700 Watts RMS at 1 Ohms
# 1x 1300 Watts Bridged at 2 Ohms
# Bridgeable at 2 Ohms
# 1 Ohm Stable Stereo
opti500x2
# 2x500 Watts RMS at 4 Ohms - ACTUAL- 400
# 2x750 Watts RMS at 2 Ohms ACTUAL - 770
# 2000 Watts x 1 Max Power at 4 Ohms Bridged ACTUAL - 1400
PWM is a bit more advanced power supply than a standard switch mode.
The use of PWM is probably due to the fact that a the HC amp will require more current than a non HC a/b, and definitely less than a class D.
I wouldn't say it makes it a better amp, but it does make it more expensive.
Not a family member here....but I sure as hell felt like one as I devoured this thread. The ONLY REASON I vandalize this tapestry of broken hearts...
22
4K
The umm1 is just a rebadged dayton/minidsp mic. I personally have a umik2 and use a regular usbc-usbc to hook it up to my laptop and a...
193
180
madmaxz
madmaxz
maryland
SicAudio
pfft
    May 1, 2024
pfft
    May 1, 2024
