Lack of subwoofer output on new head unit
  • 5
sirbash
I just bought a Alpine CDE-SXM145BT but it does not have a dedicated subwoofer output like my current head unit has which means I have a lack of preamp outputs. Does anyone have a good solution? 200$ or less please.
If it helps, I am running a 4 channel amp to power my Type R 6x9s in the front and Type R 5.25 in the back and a mono for my two 12s.
lol although that's a better looking head unit... I would rather stick with my current head unit //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Simplest/cheapest is to split the front RCAs with a Y adapter and send them to the mono amp (as long as amp has a LP filter - most do).
What amps are you running front and back? I may be able to give you some other (better?) suggestions.
I would rather not split them since you lose a bit of volume/voltage right?
How about something like this or maybe even something better in the same price range? Maybe with a line driver built in?
AudioControl 6XS (Gray) 6-channel electronic crossover with line driver at Crutchfield.com
Or this
http://www.crutchfield.com/p_2062ZXDSP1/Kicker-Front-Row.html
or
http://www.crutchfield.com/p_20603KX3/Kicker-KX3.html#customer-reviews-tab
I have a clarion 400w 4 channel amp (I think that's the correct wattage but I have forgotten and it's a PITA to take anything out from behind my seat so that's not an option) and a soundstream 1500w amp.
I think this is the amp I have http://www.amazon.com/Clarion-XR2410-Watt-Channel-Amplifier/dp/B0032FOJIY
and this
http://www.audiosavings.com/products/Website/NEW-SOUNDSTREAM-PCX1500D-1500w-RMS-MONO-CAR-AMPLIFIER--/PCX1500D.aspx
I would rather not split them since you lose a bit of volume/voltage right? How about something like...
Sure, if you can afford it, those will work great for you. Seems a little overkill seeing as you went so cheap on the HU - if you had spent that extra $250 on the HU you could've gotten all the outputs you needed plus a slew of other features. You could also drop in something like an Audiotek 7007 EQ for $70. Autotek 7007 (at-7007) 4-Band Equalizer / 9-Volt Line-Driver /
Bump.. Really need this ordered within the next 3 hours.
DO a little research at crutchfield.com or sonicelectronix.com - you can filter on head unit features. You can enter your vehicle type at metraonline.com and search for dash kits for your vehicle. Yes - you can get the single DIN kit and put an EQ in the extra din pocket - but would probably have to do some creative work to make it look clean.
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
485
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
sirbash
sirbash
United States
sirbash
    May 12, 2024
Brendon Jenness
    May 11, 2024
