lack of power
its a jeep grand cherokee laredo, the optima is in the back, i dono what the stock electical is but im running all 0 gauge wire
any idea of the size of the alt? or under hood battery? probably would be good to add that optima under the hood and get a similar sized battery for the rear to be on the safe side. how did your grounds look?
Been in car audio since 1988. An old fart.Dont understand why you ran 0 gauge wire ?? 4 Gauge should have been big enough at 15ft, and a 60 amp fuse should be plenty for that amp?? If you put a bigger inline fuse and with the o gauge wire, your drawing too much juice and ruining your alternator and not giving enough time for the battery to charge up! You may think about a bigger alt as well!I had 4 g running to an audiobahn hct 2200 at a 1ohm load and the hct 4125 at 2ohms on my mids and used a 6farad cap on the 2200,and straight 4g wire to the 4125 and a 150 anl in line fuse to a dist block, and had no issues and grounded both amps at seperate locations in a 98 xcab chevy with the stock 140 amp,all 4 gauge.
Been in car audio since 1988. An old fart.Dont understand why you ran 0 gauge wire ?? 4 Gauge should have been big enough at 15ft, and a 60 amp fuse should be plenty for that amp?? If you put a bigger inline fuse and with the o gauge wire, your drawing too much juice and ruining your alternator and not giving enough time for the battery to charge up! You may think about a bigger alt as well!I had 4 g running to an audiobahn hct 2200 at a 1ohm load and the hct 4125 at 2ohms on my mids and used a 6farad cap on the 2200,and straight 4g wire to the 4125 and a 150 anl in line fuse to a dist block, and had no issues and grounded both amps at seperate locations in a 98 xcab chevy with the stock 140 amp,all 4 gauge. ??
The kicker amps are underrated and will draw around 150A. While that does fit the bill for 4g it doesn't hurt to run 0g instead
12.5V means your alt is providing less than the vehicle+system is drawing. plain and simple.
if you increase engine RPM and the voltage jumps back up, then you know you draw more than the alt output at idle, but less than the alt rating. either turn it down when at idle or get a larger alt. more batteries will only help maintain 12.8V or so, not 14V.
if you drop regardless of engine RPM, but jump back up when you turn the volume down, then you know the alt is just too small and you should upgrade.
keep in mind that a drop in supply voltage is a drop in amp power output - most amps provide about half their rated output at 12V compared to 14.4V.
for basically a stock electrical system without major component upgrades, and with that amp, i don't see things being signficantly out of the ordinary. mind you, that voltage drop you experience might decrease output by perhaps a decibel or so, but its audibly not that huge.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
463
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
697
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
509
papafouse
papafouse
Altoona,Pa
dipitydoo
    May 31, 2024
    May 24, 2024
