kx 1200.1 power wire..
its not gonna hurt the amp but its a royal waste of 4/0. that amp would work just fine with 4 gauge.
I don't think the OP knows the difference between 4 and 4/0 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
OP, 4/0 is actually much larger than 1/0, did you mean 4 gauge?. In order from biggest to smallest it goes:
4/0
2/0
1/0
4
8
Also to actually answer your question, I ran that exact amplifier on 4 gauge in the past and didn't have any problems. Knu's 4 gauge is rated for 150A which should be plenty for that amplifier.
Sorry for my extreme newbiery.. I ment 4ga yes, it handles up to 1ga or is it 0ga?.. maybe meet in the middle and run 2ga?
I just told you 4 gauge will be fine, but if you'd like to be extra careful and minimize voltage drop you can use 1/0 if you like.
youre not gonna experience voltage drop from a 1200w amp. OFC 4g is good up to like 1800w.
1 and 0 gauge are the same thing. most 2gauge wire is cheapo stuff, "good" wire companies only make 4g and 0g
There will always be more of a drop in 4 gauge then 1/0, it's basic electrical theory.
boomzabit
boomzabit
Minnesota
bubbagumper6
