Koda8 Box help!
walterdixon
Hey, I'm about to order an 8 for the box I just made. But, I think I under-planned during box building, because I've worked it out a my box has a volume of 0.32056 cubes. On the Adire Audio site, http://www.adireaudio.com/ , theres a chart with box info on it saying you can put the 8 in a sealed box as little as .25 cubes. But, is that .25 unloaded, or .25 with the sub in?
BOX Size Notes
Low Q Sealed 0.55 ft³ sealed (Qtc=0.6) Stuff with 8 ounces of polyfill
Mid Q Sealed 0.35 ft³ sealed (Qtc=0.7) Stuff with 4 ounces of polyfill
High Q Sealed o.25 ft³ sealed (Qtc=0.8) Stuff with 4 ounces of polyfill
Small SQL 0.5 ft³ tuned to 35 Hz, Ø2" x 11.5"L Use 25 Hz subsonic
Large SPL 1.0 ft³ tuned to 40 Hz, Ø3" x 9"L Use 30 Hz subsonic
Large SQL 1.0 ft³ tuned to 28 Hz, Ø2.5" x 14"L Use 25 Hz subsonic
Thats the chart on the site. Now, what does Qtc=0.8 mean? If that means .25 cubes loaded, could I get away with .24056?
Also, what does it mean when it says stuff with 4 ounces of polyfill?
Finally, if I don't have enough space for the Koda8, are there any subs that require less space?
Sorry for the barrage of questions but I wanna get ordering!!
Thanks,
- Walter
.25 after sub displacement
Polyfill is the stuff you find in cheap pillows, get some at wal mart.
If you dont have enough space make some.
The Koda 8 is a really nice woofer, i gonna get 2 ( eventually)
...which would put me pretty much right where I want to be...but, I don't feel like making another box so I think I'll go with the ring for now and maybe do the 1/2" down the road. Thanks alot for the help supa_c and for the lightning fast responses!
Oh, a little off topic, but what kind of amp should I get for this. I want to keep it under $100 if I can, maybe a Profile 200x1?
walterdixon
walterdixon
Ontario, Canada
walterdixon
