kinetik 2400....hooking up ring terminals...
aaron7114
Pretty dumb question but I just want to double check. On a kinetik 2400 battery (prolly like this on all kinetiks) on the positive and negative it has a screw and a nut. Now are you suppose to put the ring terminal for the positive and negative between the head of the screw and the but or do you just put the nut at the very top of the screw and then screw the screw and nut down on top of the ring terminal
Option A (in order)
Screw
Ring Terminal
Nut
Option B (in order)
Screw
Nut
Ring Terminal
I'm guessing that it prolly wont make much of a difference either way since everything will be touching. But I just wanted to double check.
Yeah, pretty much as long as is held solidy in place against the terminal you should be fine... whichever way you think looks prettier //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Joseph.
aaron7114
aaron7114
Arkansas
audiolife
