Kinda new and installing stereo in son's truck
  • 5
Rangerboats
30
La.
 When I was young, over 30 years ago I was into Stereo's but have not done any in a very long time. I'm  installing a stereo into my sons truck, a 2012 Toyota 4 Runner. I was hoping for any and all help or guides that I could receive. I spent a week looking around and reading and I've ordered the items, remember this will be my sons first stereo.  Rockford Fosgate punch 300.2 for mids and highs. SSA Evil 6.5 components, a single FU Audio 1500Ti 4-ohm to run at 2-ohm to help on electrical, Hifonics brutus 2016 amp to run at 2-ohm. Pioneer 500ex HU, Knu RCA, Knu concept 0-ga wire for sub amp and Knu concept 4-ga for mids/highs amp. Knu 0-ga for Big 3 run and he also has a Duracell Gel battery.
 I will need to build a subwoofer box but I'm doubting my ability to do that and I do not want to use a prefab. Am I missing anything or made a bad call on any Item? Back when I was young (30 years ago) Hifonics was great stuff but I'm not sure now days, so was Fosgate but still not sure. I only knew about the FU audio and the SSA from reading around, I've never listened to them so I'm taking a chance on pretty much everything.  Thanks for your help and advice.
Do not buy a 4ohm and run at 2 ohms. That amp will hardly tickle the 1500ti at 2 ohms.
It’s always a better idea to run it at 1 ohm and turn the gain down if your electrical can’t keep up instead of wiring to a higher ohm load.
So I should order the 2-ohm subwoofer and run it at 1-ohm? or buy a different Amp? I just ordered the sub from FU so I'm betting I can change the order in the morning
 Edit...it is my understanding the hifonics does 1400 at 2-ohm and the sub is rated at 1500 rms? so the amp will not do what it is rated at? or the subwoofer is far better? Should I buy a different amp or get a FU 1250 subwoofer? thanks, I'm very glad I ask for help because I'm in over my head.
I would swap to the 2 ohm subwoofer.
Those hifonics don’t do rated. The 3016 dynoed 1800 watts rms.
With impedance rise you will most likely rise to 4 ohms and not be seeing much power at all.
I personally would pick up a Wolfram 2400 amp to run at 1 ohm on the FU 1500 or if you want to keep the amp I would go with the FU 750 subwoofer. Which are fantastic subwoofers btw.
Ok So how about the NVX Jad1200.1 the dyno said it was a true 1200 watt amp and it is still a close to budget amp? Would it work with maybe one of the 750FU or the 1250FU subwoofer?
 Also I don't sem to be able to find the wolfram amp for sale. thanks
You won't regret that Wolfram amp, if you go that route. Too bad I can't get mine hooked up until next summer...
I would def follow Popwarhomie's advice. We got a few very experienced car audio gurus here in this forum. Btw, I might add your a cool dad for hooking up son's 1st stereo. I never had that when I was younger....always worked to get what I wanted. I'm hoping I can do the same with my daughter when she starts driving.
Thank you for making a great product. I read alot on the 6.5 Evil being a great set of speakers and that is why I bought them.  I'm so glad I came here and ask for help because I almost made some big mistakes. I've canceled my order for the hifonics amps and stopped my order on the FU Audio sub for now, Once  I figure out which amp and subwoofer to get I will be buying a FU sub though.
 So I need to order the wolfram amp and then get the 1500TI in 2-ohm to run at 1-ohm? Or the NVX 1200.1 and the FU 750 to run at 1-ohm?
 I remember as a kid my Stereo being a very big deal, all my friends loved it and people were always coming up to listen to it and I wanted my son to XP that same thing, except the noise laws in our town are way different now and they give out tickets for even small systems now days. I never understood how a motocycle can come thru and give you a massive head ache but the stereo is a no go.
 Thank you guys so much for the help. I'm very grateful for the help
EDIT....I just looked at the s1=soundquded 1250 another guy posted. should I go that route? I'm sorry for asking but I really don't know much about it.
ok after thinking about it I'm going to get the wolfram amp and the FU audio 1500TI to run at 1-ohm, The SSA evil, Fosgate punch 300.2, Knu wire, big 3 wire and rca jacks, pioneer 500ex. That should do it but now off to find out some one around here who can build a box. I need 2.5 cu at 32 hrz i think is what the website saide.  Thank you guys so much for all of the help
I need help with one other thing. I'm running the big 3 on his truck. What amp in-line fuse do i need to use if I'm doing a run of 0-Ga from the alt to the battery? Then I just run a ground to battery from frame of truck and a ground from motor block to Frame? Thanks
Dayuuum!! You had more money to spend on audio than I did back then. LOL 👀 👀:poop:🤣
14
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Rangerboats
Rangerboats
La.
Rangerboats
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
