Kicker CVR 12" DVC 2OHM.
yea, they have changed. but only for the worse. i had problems with the coils seperating and tensil problems too... had about 8 of em due to a good warranty but every time had the same problem.
you going sealed or ported? personally i'd port them. if going sealed i'd go 1-1.5cuft a sub, ported about 1.75-2cuft. a sub. and you'll be fine with that 600wrms to each, i'm running 600wrms+ to my 15" cvr and it's taking it.
It's been a while since I posted. The CVR's are now shot. This is the 4th pair the amp has owned!! I'm not going back to Kicker. I'm looking to pickup a set of subs that will suit my amp.
Any ideas?
Wow, 1 year old post...
Either way, I got to believe there is another variable here... Shouldnt be destroying subs like that. How high are your gains, how hard are you on the volume knob? Are you using bass boost? Just doesnt seem right to be going through 8 subs in less than a year.
I've actually been through 8 subs in 7 years. My subs are set on 3 out of 12. No boost from the h/u. The amp gain is barely at half. It seems my problem are the tenil leads keep snapping off. I guess that's a poor design. The other sub is hanging on. I'm not sure how long.
I'm thinking of replacing them with some Type R's. I haven't really looked at the speaker design. It has to be better than Kicker's.
1FstFormulaV8
1FstFormulaV8
Portsmouth, Ohio
Polecat
