Kicker Amp and Sub Install Questions
Hjbennett
I have a 2011 Hyundai Sonata and want to add a sub in the trunk. The car has a cut-out in rear deck for an 8" open air sub from the factory. But I actually want a bigger sound. Due to budget constraints, I ordered a Kicker 12" L3 and a Kicker ZX300.1. I have a friend who does stereo system installs and builds enclosures. I've seen and heard his system and it sounds great and with his custom fiberglass/mdf enclosures it looks professional.
I've always either ran stock systems or when I was much younger, had a system installed for me. I've been reading the forums trying to educate myself as much as possible so I won't appear to be a ******* when I'm discussing and "helping" him do the install and make the enclosure. I know I want it ported. The specs on the sub are as follows:
SIZE [in, cm]: 12, 30
IMPEDANCE [Ohms]: 2 or 4 DVC
POWER WATTS [peak/RMS]: 800/400
SENSITIVITY [dB 1w/1m]: 86.3
MOUNTING DEPTH [in, cm]: 6-1/4, 15.8
MOUNTING DIAMETER [in, cm]: 11-1/16, 28.1
MIN SEALED BOX VOL [cu. ft, L]: 1.25, 35.4
MAX SEALED BOX VOL [cu. ft, L]: 4.6, 130
MIN VENTED BOX VOL [cu. ft, L]: 1.75, 49.6
MAX VENTED BOX VOL [cu. ft, L]: 2.25, 63.7
and the amp:
Amplifier Class AB
Number of Channels 1 - Mono
Total Peak Power Output 900 watts
Total RMS Power Output 300 watts
Maximum Input Gauge Size 8 AWG
Minimum Impedance Unbridged 2 ohms
THD at Rated RMS Power 1%
Speaker Level Inputs Yes
Preamp Outputs No
Built-in Crossover Low-pass (LP)
Low-Pass Crossover Frequency Fixed at 80 Hz
Subsonic Filter 0 - 25 Hz
Signal-to-Noise Ratio 96 dB
Bass Boost 0 - 12 dB
Bass/Gain Remote Yes
I would say a ported enclosure firing toward the trunk would be optimal for sql.
Lotta greek there. My questions:
-First, will this setup be adequate for no-earth shaking bass, but a nice sound.
-For SQL what should be the cu. ft. of the ported enclosure?
-Which tunes the sub for best sql, size of port or size of enclosure?
-Enclosure material: I'm going to use MDF, so 3/4"? carpet for covering? Or is covering just cosmetic?
- Should I remove plastic cap from the empty sub on the rear deck for sound to enter cab of car?
Any other basic information you feel like tossing out here so I can at least understand what he's talking about will be greatly appreciated.
Ive been lurking here for some time, so I know there are some knowledgeable folks here. Share some of that wisdom. //content.invisioncic.com/y282845/emoticons/bowdown.gif.b85b23b82970bd22fb6b549c3392f016.gif
Hjbennett
Hjbennett
Yazoo city, MS
Hjbennett
