Kenny's rant/fix thread
They were sold out //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Only analog ones..next Walmart is 12 miles away...
What's the 9V battery test?
LAMEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
I'mnot sure about the 9v, Give chevyaudio a PM.
+ speaker wire on the + on batt and - on the neg. If both subs pop in or out the same you are good. If one pops in and one pops out, they are out of phase.
Confused a little, there are two positives and two negatives per sub
If you can get on aim, let me know.I want to ask you a couple q's about when you were playing with it.
I'm on AIM, kennethrpollock
Also, NoL, to answer your q: The BTL took 10kw in the test session... but it was 10kw of CLEAN power, not clipped //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Good point
Learn something new everyday //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Nope, two positives and two negatives per sub
Waste of wire, but OK...
If you cant trace each wire from the amp to the plugs on the subs you will need to pull them out to check phasing.
I am still really lost on the smoke part though. Unless a coil is wired completly wrong and they were shorted out. Only thing I can think of...If that was the case, I am surprise they didnt go into protect or fry.
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
NoLimit
