JVC Sq??
  • 6
from the internal amp or the eq onboard? They always sounded fine to me going either avenue. IMO the other amps make more of an impact on sound
both really, just tryin to get a idea of how they hold up against other brands.
im b goin from a pioneer to maybe a jvc and just seein if ill lose any sq
shouldn't. I like the sound of the JVC hu's over the pioneers personally, but I hate the JVC remotes and controls. Just make sure you get good outboard amps and it won't even matter. I recommend rockford power series
what u mean by outboard amps?
if you mean by sub and comps amps, i was lookin at sundown
i like the avx1 i have. i'm probably going to get the new jvc chameleon. only complaint i have is the low preout voltage on the sub, which is a very small issue. i believe it's 5v instead of 2v on the new ones anyway
A HU is a HU is a HU. Find one with the features that you like at a price you're willing to pay and buy it. You aren't going to hear a difference, even in the built in "amps" (because all HU power is built on pretty much the same chip regardless of brand and they all ****).
Google do it translate what ever i do
256
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Lets Get It
Lets Get It
Where im at
helotaxi
    May 24, 2024
    May 23, 2024
