Just installed speaks 720prs not good!!
tryan77
I just installed a pair of pioneer 720prs components in my 07 Explorer and they sound great...until i turn them up. The woofer is slapping on the door panel. I did not use any mdf spacers but i did you use the 6.5 converter kit which is very thin. I have no idea how to fix this. Spent all friggen day wirin these puppies in and now i have to deal with this //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif Any ideas?
if it will fit-put the grill on the speaker, put door panel back on...the end
Dammit //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I had it on there but i was worried that the panel wouldnt fit back on. Youre the man.
You win 1,000 car audio internetz.
Thanks man.
Here's what I did, birch rings with PE gasket tape on either side:
Yeah but that wouldnt work in my app and it would actually make it worse because then the woofer would be slammed up against the panel. You must have alot of space between your door and the panel.
sounds like on ur door panel the stock cup is still installed. some thin plastic lining around the grill on the inside.
cut this off. (i use utility knife with fresh blade and some patience) or u can use an angle grinder to wear off the plastic.
then reinstall.
Mike
I do have decent space. Sorry my brain's not working today:crazy://content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
most days actually.
tryan77
tryan77
Milwaukee
mcsoul
