just got 2 subs only 1 works
sotallytober89
ok so i just bought 2 subs from my friends
there some 12" e types
i have been running a single sub off my sony xm-1252GTR amp
this amp is supposed to be able to power two subs which is why i bought some
well i have tried every **** combination of wiring to the terminals
and no matter what only one works
its as if im only getin power to one set of positive and negative terminals
i switched the wires a few times, and both subs work and have been on, just not at the same time
any ideas???? i have not been this frustrated in a very long while
thats it
no reasoning, no explanation?
i bought the amp new and i shouldnt have problems with it, not everyone can just afford to "get a new amp"
is there any other thing that could be wrong with it
like i said it seems as if im just gettin power to one set of terminals
it is a bridgeable amp but i dono if that has anything to do with it.
i did have it brdged when i was running my last sub
thats what i was thinking about doing
but i had no idea if that was a even smart idea, i figured i would end up catching my car on fire or soemthing hah
so this is realtively safe correct? and will the amp still split the power correctly
im(supposed to be) pushing 340 rms bridged with this amp
awesome
so how exactly do i go about this
do i take all four wires from both of my subs, twist them together and then twist another pair of wires to that and run it to the amp?
awesome
they are single 4 ohm woofers right? also is your amp 2 ohm stable?
yes about the woofers
and in my amp manual, in one of the diagrams it says min. 2 ohms, so i assume that it is stable at 2 ohms
yup good. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok take one wire from woofer A's positive terminal and hook it to woofer B's positive terminal. do the same for both negative's. then take a wire from each of woofer B's terminal and bridge it to the amp.
ok so i basically hook up both woofers with one set of wire
then stick another set of + and - wire in one of the woofers and then back to the amp?
im sorry im reatrded, you even gave me a diagram hah
im really sorry if that doesnt make sense
and thanks for the help
ya but you only need one pair a + and - wire coming from one woofer to the amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sotallytober89
sotallytober89
colorado
skadude016
michigan born
    May 14, 2026
michigan born
    May 14, 2026
