just another noob needing advise
Alright, i prefer sub up port back but Is that the best way to go in a hatchback suv?
I'll see what works best but with this box as long as the port has a wall or corner to load off of you'll be good. Shoot me those max dimensions when you can.
Sent from my SCH-I605 using Tapatalk
I will pm you those as soon as I get home, if it helps I know my current 2 15s box is 38in wide and it fits pretty snug in between the wheel wells
A tri-bend/fold tline will be 33" wide so you're good there. I'm thinking sub up port back will be what we're looking at. With that said, the 33" would be the height actually if it's doable. If not, it will be sub side firing, port back....or sub inverted on top with a lower height and wider enclosure.
I like the sub up, port back option (with sub mounted normally) 33 for the hightime is fine, I believe my current box is about that hight
Sprinkin8tor
Sprinkin8tor
Easley, SC
Sprinkin8tor
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
