Just a Clarification Before I Buy
Dynasty
I am considering buying a Kenwood KAC-8103D amp to power my single 12" Kicker CVR, but before I do I would like some clarification on the specs. According to Kenwood's website, the amp can do 500W RMS @ 2 Ohms. On Sound Domain's website, the amp can do 500W RMS @ 2 Ohms bridged. The amp does not need to be bridged to get 500W RMS @ 2 Ohms, correct?
Kenwood- http://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-8103D
Sound Domain- http://www.cardomain.com/item/KENKAC8103D
On a side note, any other suggestions for an amp that is under $120?
is ur cvr single voice coil or dual and what ohm,
2nd it is a mono amp it is one channel so it is always bridged i believe that amp has 2 speaker outputs and it bridges them internally u would not bridge it on the outside if ur using 1 svc sub just hook up to ine side not bridged
also what is the watts rms on the cvr,
this amp 500 watt rating is at 14.4 v i doubt unless u upgraded the hell out of ur electrical system ur car is constant 14.4 prob around 13.4-5 so it wont be 500 watts rms it will be less u have to look at alot of things when buying an amp not just rms watts, i would look in the clasifieds for a higher end used amp that will better suit ur needs
That'll be fine then
You can't 'bridge' a mono amp.
The dual outputs are simply run parallel internally, so it's like one set. It's just for ease of wiring two subs.
Looks like you'll be fine.
Dynasty
Dynasty
Cleveland, OH
DejaWiz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
