"Junk in Her Trunk" VW R32
  • 5
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
716
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
crnacnac
crnacnac
Pasadena,CA
crnacnac
    May 12, 2024
Brendon Jenness
    May 11, 2024
