JMAC, i need help
  • 1
BASSBOY
Beware Of The BBB
Hey man,
ive been designing a box for kicker comp vr 12, and i have built one on win isd and everything looks cool, but i am not sure on what all that stuff means. do you think that if i sent you the file of the box, could you check it out and tell me if it would work?
i wait your reply
DAN
well i use win isd beta, will it work? i think it should. send me ur email and ill send it off k?
thanks soo much
p.s
i will send two, the first one will probobly work the best for me but the second has a higher port volume and will have to have one turn in it. and in the second the mach value is numerically lower, so i dont know what it means, but it seems to be importance
thanks again
118
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
98
441
337
748
BASSBOY
Beware Of The BBB
BASSBOY
Alix, Alberta
BASSBOY
    May 12, 2024
Brendon Jenness
    May 11, 2024
