1st enclosure plz help!
  • 1
M3thod_Man
Wassssssabi
I’m getting a jl 500/1 and a jl 10” w7 within a week, and I don’t have a box yet. I probably want to build it on my own, but I need a little guidance. I want a sealed box at around 1.25 cubic feet after displacement of the sub. Heres my list of questions (basically a rant) = ).
1st. For SOUND QUALITY purposes only, should I make a box in a different shape than rectangular or boxy? Is there an audible difference generally speaking, considering my 1.25 cubes? Plz only answer this if you are a sound quality buff and know what your talking about….
2nd. As far as the materials go I’m thinking either 1” MDF all the way around or ¾ all the way around and stacked on the baffle… what do you guys suggest?
I’ll need wood glue, liquid nails, screws and of course the board, that’s pretty much it right? Any brand names for wood glue or places I can get these items/ recommendations?
3rd. My last (I promise J ) question is do you guys think I should brace it? Any type of bracing you suggest, like the triangles on all joints?
When you brace, do you just pile on wood glue and fit it in, or do you also nail/ screw it in? do the braces have to run parallel to the baffle?
4th. As far as constructing it, assuming all the cuts on the board are correct, how do you assemble the sides correctly? Is there a standard orientation or do you just plop the sides on with glue and forget about it?
http://www.dancetech.com/aa_dt_new/pa/construction.CFM
Does ^ this guy know what he is doing with the 1” wood bits in the corners or is this overkill?
http://www.ofsoundmind.com/osm/speakers/subs6.html
is ^ this necessary or is carpeting it just fine to seal it?
Thank you VERY MUCH in advance for even reading this much….all these questions give me quite a headache…. I know some of these questions may be dumb, but what can I say its my first enclosure…thx alot
Peace out, Merry X-mas, WERD
an X or / pattern? any pics? i dont believe im even remotely familiar with either, heh sorry = (
bracing is usually always parallel to the baffle right? or does it matter ( i thought for airflow purposes it would)?
Awww.... is it ok to just use that portrait looking brace? and if i had 1" MDF do you think bracing would even be necessary?
Also, somone told me that the bottom and top of the box are glued flat to the top and bottom of the baffle and back.... and then the sides surround is wedged inbetween the top bottom and front back.... is this the "standard" orientation, or would anything similar to this with the sides switched around be sufficient?
Thx alot for your time I'll pass the knowledge on to other peeps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
690
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
924
M3thod_Man
M3thod_Man
Lynchburg VA
M3thod_Man
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
