JL w7 AND WIRING METHODS???
des343
so i am a little confused they are dual 3 ohm coils (the 12s) Google or worse JL themselves dont seem to cover this very well or at all i saw
So dual 3 ohms...yet only ONE set of terminals and a ending load of 3 ohms....
So how do i wire these differently...other than 3 or 1.5 for a pair
and how can i wire FOUR (4) of these what can my ending result be...
can i create a rise on these so i can drop them?
i have not a clue how to wire one at anything other than 3 ohms or 2 at anything other than 1.5
i HAVE 2 and potentially be getting another 2 to make a total of 4 but i want to see my wiring options
I looked in to this a while back on their DVC 3ohm sub. Fairly retarded. You are either running at 3 or .75. With 4 you could keep it at 3 ohms by running two parrallel sets of series, if that makes sense. I don't know what your amp is though and what it will take, I know mine wont tecnically take a .75ohm load.
well i took my 4 t1s out do to being an idiot and blowing my matching amp Audiopipe 3000d (my own stupidity please dont hate on the amps lol) anyways so i dont quite have the power so thought id throw my 2 w7s in save space blah blah...(i know they dont play all too well with this amp on their own) but i was hoping to be able to get 1.5 maybe 2 or so ohms after rise or maybe even 3 ohms to be able to bridge 4 of them as close to that 2 ohm mark that the ap amp likes.
so basically id be trying to hook them all up to the one AP till i got the money to get a second t2000.. then ill just run both of those.
but i got a deal i can hopefully trade my 4 t1s for 2 more 12 inch w7 (i just think 4 w7s would b cool not even a HUGE fan tho i like the subs quite a bit)
BUT
on the other hand i have a guaranteed deal a guy wants to give me a soloX18 for my 4 t1s
im not sure what im going to do yet so thats where the actual how i can wire the w7s come in i need to know if i could even put any decent power into 4
thanks for help!
How much under 1 ohm and okay ill prob wire it at 3 and the amp does 2000 rms at 4 ohms bridged..so it should get loud
But my electrical honestly isn't up to nar for a solid 4k rms I need more work no doubt
what amp are u using that does that kinda power?
fix that before moving on...or you're gonna blow some more equipment
Anyone think 4 of these things can get down?
yes, in the proper setup/box they can indeed get down with their bad selves //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Lol thanks and well I got a stock 120 amp alt zero gauge ran through the entire car back to a red top I can run around 2500 rms without voltages dropping under 12.
And the ap3000d does 2000rms at 4 ohms bridged.
I have a t2000 and I plan to buy another when my funds are better and do the big 3 and change out my batt for a couple of larger batts
The box for tnem I already have it will b roughly 10 cubes after displacement maybe more like 9. They are a little bigger than what was in there...and ported to 32 hertz
des343
des343
Kalamazoo, MI
$LICK CALIFA$
