JL G6600 6 channel
plugitin
She Bangs
JL G6600
Good condition, works like it should, case isnt perfect. 8 out of 10 for looks, 10 out of 10 for performance
Excuse the dust on her...been sitting awhile. PM me on here, or text me at 906-458-7636 for a faster response.
160 shipped
Op, I was gonna ask about the specs but I found it, so a quick cut and paste to help ya out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
•6-channel car amplifier
•at 14.4 volts:◦75 watts RMS x 6 at 4 ohms (110 watts RMS x 6 at 2 ohms)
◦200 watts RMS x 3 bridged at 4 ohms (150 watts RMS x 3 at 8 ohms)
•at 12.5 volts:◦55 watts RMS x 6 at 4 ohms (75 watts RMS x 6 at 2 ohms)
◦150 watts RMS x 3 bridged at 4 ohms (110 watts RMS x 3 at 8 ohms)
•differential-balanced inputs
•Advanced Rollback Protection System
•frequency response: 10 to 25,000 Hz
•variable high- and low-pass filter (50-200 Hz, 12 dB/octave)
•switchable bass boost (0, 6 dB at 48 Hz) on channels 5 and 6 only
•optional wired remote control converts switchable bass boost to fully variable (0-12 dB)
•Absolute Symmetry™ Class-AB amplifier design
•MOSFET power and output stages
•preamp inputs
•speaker-level input with optional converter
•4-gauge power and ground leads and a 60-amp fuse recommended — wiring and hardware not included with amplifier
•no onboard fuses — when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended
•9-1/4"W x 2-1/2"H x 18-1/16"D
plugitin
She Bangs
plugitin
Da U.P. eh?
plugitin
