JL G6600 6 channel
  • 6
plugitin
She Bangs
6,906
Da U.P. eh?
JL G6600
Good condition, works like it should, case isnt perfect. 8 out of 10 for looks, 10 out of 10 for performance
Excuse the dust on her...been sitting awhile. PM me on here, or text me at 906-458-7636 for a faster response.
160 shipped
Op, I was gonna ask about the specs but I found it, so a quick cut and paste to help ya out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
•6-channel car amplifier
•at 14.4 volts:◦75 watts RMS x 6 at 4 ohms (110 watts RMS x 6 at 2 ohms)
◦200 watts RMS x 3 bridged at 4 ohms (150 watts RMS x 3 at 8 ohms)
•at 12.5 volts:◦55 watts RMS x 6 at 4 ohms (75 watts RMS x 6 at 2 ohms)
◦150 watts RMS x 3 bridged at 4 ohms (110 watts RMS x 3 at 8 ohms)
•differential-balanced inputs
•Advanced Rollback Protection System
•frequency response: 10 to 25,000 Hz
•variable high- and low-pass filter (50-200 Hz, 12 dB/octave)
•switchable bass boost (0, 6 dB at 48 Hz) on channels 5 and 6 only
•optional wired remote control converts switchable bass boost to fully variable (0-12 dB)
•Absolute Symmetry™ Class-AB amplifier design
•MOSFET power and output stages
•preamp inputs
•speaker-level input with optional converter
•4-gauge power and ground leads and a 60-amp fuse recommended — wiring and hardware not included with amplifier
•no onboard fuses — when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended
•9-1/4"W x 2-1/2"H x 18-1/16"D
last time you powered it up to test?
more pics of the sides and controls?
thanks
Probably 6 or so months ago. Tested all channels in my truck before i sold the truck. Will get you pics tonight or tomorrow. Thanks!
$100 shipped.
too low bro
---------- Post added at 03:14 PM ---------- Previous post was at 03:13 PM ----------
Just noticed that three of the set screws are missing from the speaker inputs also...150 shipped
10
247
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
925
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
185
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
599
plugitin
She Bangs
plugitin
Da U.P. eh?
plugitin
slater
    May 2, 2024
slater
    May 2, 2024
