JL Audio 500/1
But MMATS amplifiers can go down to 0.5 Ohm, just in case your looking for an amp that will go lower.
Only if you wanna trade for my JL Audio 500/1........//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm broke right now, trying to sell the amp as I still have a Funkin Audio mf 400 to power the subs
Nope, only 1.5 to 8 ohm stable.
I had a 250/1 and got it down to 1.333, but it would go into protect at 1 ohm. The amp is rated to output the same power a 1.5 to 4 ohms. Somewhere around 250 at 8 ohms. If you were to run it at 8.1 you would probably cause a massive chain reaction in the power supply which would spike the voltage to 1.21 jigawatts requiring you to get a flux capacitor, Mr. Fusion and a couple of old beer cans to run it.
Yes, but all that current draw will **** the power out of the ignition system and the car will not get to 88 MPH. I've tried it. Not possible. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
f'in JL amps.....
JT1979
Hat Keeps Scammers Away
JT1979
FLORIDA
dleccord
michigan born
    May 14, 2026
michigan born
    May 14, 2026
