jl audio 1000/1 v2
rick265
ny
I have two jl w6 v2's in jl box that was powered by a jl A1400 amp but i sold it to my friend because it wasn't powerful enough so I ordered a jl 1000/1 v2 amp will this new amp draw be too much for my cars electrical system to handle?
hey guys help me on this....i got 2 13w7 and two 1000/1 v2 with a 300/4 v2 and a set of vr600 csi jl component with a pioneer head unit p6900ub. i wanna know do i have to upgrade electrical or anything else to have the full potential of the system...i want it to be loud *** hell...let me know what else i need...thanks.
hey guys i got 2 12" W3's 4 ohms and i have a kicker KX25001
I was wondering if i crank my music in my which is 40 what wuld b the best wattage it be at
rms is 300 max peak is 600
any1 know?
any1 know?
If you're wired at 4 ohms, or 1 ohm, either way its bad with a kx2500.1...that amp runs at 1500rms at 4 ohms and 2500 at 2 ohms. The 2 ohms doesn't apply to you. 750 rms would be going to each sub and conclusion, you're going to destroy the subs. Get a monoblock class d amp that does 600 rms x 1 at 4 ohms or a 2 channel 300 rms a piece (each channel) at 4 ohms. That's if your subs are wired to 4 ohms and not 1. Either way that amp is way too much power for those subs.
hey whats up i have a proble with my set up somewhere. i have 05 nissan maxima with JL1000/1v2 Class D Monoblock Subwoofer Amplifier, 2 12"JL w6/v2 and a Batcap 400 setup with entire trunk lined with extreme dynomat, yet when i turn the volume up all of the way base cuts out and the blue led lights up saying low voltage. do guys know how can i get rid of that so that it work properly again?
rick265
rick265
ny
chriswho
michigan born
    May 14, 2026
michigan born
    May 14, 2026
