JL 1000/1 problem
ChuteBoxe515
The Man
ok, this problem ia being dictated to me from 60 miles away, but apparently, my friend has a SX and a 1000/1...he has had the amp at 1 ohm for over a month now with no problem, yesterday he said a "sonic noise" was coming out of his sub...all four LEDs were on...he unplugged everything and rehooked it up, now the only lights on are the power light and the low "omega sign"...I am assuming he means low ohms...the thing is, the sub isnt hooked up, just power ground and remote...and ideas?
ur friends an idiot... with that amp it should have been wired to 4 ohm.... instead of 1... he might have finally messed up the amp.. i had the exact same thing.. 1 sx12 and a 1000/1 but it was at 4 ohms...//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
just sounds like the amp is messed up and now sending some sort of feed through the other speakers... tell him to disconnect the rca's n c if it stops..
lol...tool:naughty:
"but why would the ohm light be on now with no speaker hooked up to it?"
simple.... jl is not like other amps that can drop 50-100% there impedence... ie..
orion ... rated at 1 ohm prolly will run to 1/4 ohm....
Jl slash amps will NOT run for long like that... there meant for 1.5-4 ohm only!!! the light s prolly stuck on now cuz he fried a channel or the board... i think hes sol..
kinda serves him right tho....
edit..
especially since that sub/amp runs great at 4 ohm
the mysterious "sonic noise" is only through the sub...fyi
yea seems impossible a sub makes noise not hooked up to anything....//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif .. bad signal ???i got nothn... have him bring it in so the guys at the shop can tell him what an asshat he is
And i can tell by his enriched self taught version of car audio talk that hes clueless...
sonic noise....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
low omega??? wtf
i wonder why he wired it 2 1 ohm......dont they produce about the same amount of power at 4 ohms as they would produce at 1 ohm
thats what i asked him---his response
"i thought JL was good enough to handle it"
haha i told him to switch to Orion
That's why you don't run an amp that's not 1 ohm stable at 1 ohms lol. Does he have warrantly on it from JL at all? Even if he does the warranty's probably void cuz he ran it at 1 ohm, but who knows if they'd actually be able to tell if it was or wasn't.
lmao.... for 1 jl>orion... period
jl is good enough to handle it???? who is this idiot???/ does he even no what amp he bought????? its like 50 watts difference from 1.5 ohm@14.4 volts, to 4 ohm@10.5 volts.. lmao.. this kid is to much:rolleyes:
i will be sure to direct him to this thread...and the way he is, you will know it is him by the new registration date and post count person trying to defend the choice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
They dont have idiot protection warranty with jl.... //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
And most good amps like i said if u READ .the posts.. will run at least 1/2 there rated impedence...noob
ChuteBoxe515
The Man
ChuteBoxe515
IN
SQChevy
