Jesus, now a NEW noise from engine, help fellas
Defective clutch disc ?? Those springs somtimes pop off //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
And maybe your clutch alignment is off ??
Lightweight flywheel has different tooth count than oem ????
Starter gear sticking open ?????
But it goes away when you press clutch hmmmmm
Bad ****** syncros
its ****** related, not motor.. pushing in clutch will not make a motor tick. my friend has the same noise and it was the bearings in the ******. ive had it happen plenty of times and it was either throwout or main bearing on the ******. u ever change the thrust bearing in the end of crank?
OK, the noise only occurs now when making a sharp left turn at speed, WHILE the car is in gear, but as soon as you push the clutch in, noise goes away.
Keep 'em coming guys. I'm doing a complete inspection of the motor/****** on Tuesday.
ls2poweredgoat
Womanizer
ls2poweredgoat
Port St. Lucie FL
Johnny Law.Lulz
