Jesus, now a NEW noise from engine, help fellas
Clutch, throw out bearing (replaced twice), flywheel, and pressure plate were replaced 6 weeks ago.
Have another shop check those guy's work
Sounds like your Main bearing is going out if you have gone though that many clutches..
My 300k mile Isuzu pickup had just enough Main Bearing play that it would destroy a throw out bearing every 30k miles.
Probably a good idea to check this too.
If you need anything let me know my boy has an 02 single cam vtec accord motor
Or if you need parts you know I work at napa son //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Could also be the speedo cable getting fawked or when was the last time you adjusted the valves ??? Mine tick like a tweeker lol on my h22a
Just saying. But are you sure you tighten everthing in the flywheel clutch area. Just mabye a bolt was left loose. Hence noise goes away when clutch is pushed in. Did you use lock tight on all the bolts. Just saying. Throwing it out there.
Flywheel/clutch/pressure plate was replaced well over 6 weeks ago, and there hasn't be a problem. Everything was torqued down to spec.
well idk bro. i'm no honda guy.
is something loose on top of the motor?
:facepalm: STFU, JCO. You're not an engine person.
Clutch disengaged = No rattle
Clutch engaged = Rattle.
It has to be something involved with the drive train, and most importantly the clutch. I say the bearing.
Can you get cheap fuel injectors for a '98 V6 Mustang?
And ECU plzz
Man, I feel really bad for you since lately your car has gave you so many problems. The problem sounds like a throwout bearing to me which is weird since you just replaced it.
What seems weird is that you also just added lucas oil to your transmission yesterday. Since it would be a lot of work to drop your ****** again and we're not sure if it's the throwout bearing, it may be a good idea to drain that oil and try Honda MTF. The stuff is perfect for our transmissions.
Good luck!
:facepalm: STFU, JCO. You're not an engine person.Clutch disengaged = No rattle
oh, i see you came up in this bish with the right answer //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
you stfu. you fckin ***
ls2poweredgoat
Womanizer
ls2poweredgoat
Port St. Lucie FL
Johnny Law.Lulz
