Jensen VM9311TS help
thaFranchize2b
KY
hey I got a Jensen VM9311TS head unit and I know how to install everything except that Pink E-Brake wire... Where do I connect it? It's supposed to hook to the E-Brake but where does it go? I drive a 1998 Toyota Camry if that helps thnks
BTW Im not tryna bypass it to where I can watch Movies while Im driving, I just wanna kno where that pink wire goes
When you do get it hooked up can you let me how it is. i am looking into a cheaper 7" flipout. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif thanks. Sorry i couldnt help more.
i didnt do anything other than wire it as you would any other HU, and left the e-brake wire unattached. no switches or codes or anything
Did you buy it used? Once the code is input, you never need to do it again, even if the unit is unhooked from all power
nope, i programmed mine on my work bench, then unhooked it and installed it in my work truck about a week later, didnt need the code. Switched it to my comp vehicle when my other deck crapped out, still didnt need the code. Had it out of the truck for 2 months, sold it to a friend and still didnt need the code/ground
So your saying I dont need to hook it up to anything? Ive been told that if you dont hook it up, you cant play videos at all... You have to have it hooked up or something to put that code in dont you? (I already know the code and all that, but I just need to know what to do with that wire)
thaFranchize2b
thaFranchize2b
KY
thaFranchize2b
Mike Mccabe
