Jeep Grand Cherokee 4wd
  • 4
Ok I have a 95 GC and its 4wd all the time and its killin me in gas, isnt there something i could do or take off to make the front wheels stop spinning all the time? We dont have much bad weather down here and I dont go off-roading im just looking to get some better gas mileage, thanks for any input:)
The main thing you could do is swap out the original Full time 4WD Gear Box with a Select-Trac Gear Box.
This way you would still have 4WD Capabilities, but could also drop into 2WD for better gas mileage.
It's a fairly common and straight forward swap if your reasonably mechanically inclined.
http://www.jeepforum.com
Several folks there have done a similar swap, so it wouldn't hurt to drop in and have a look.
removing you front driveline would be the most cost effective way to achieve your goal...but, you will not have 4wd in the case a storm moves through your town and your front axle will still have a ton of rotating assembly being unneccisarily spun(hurting you fuel mileage).
the best(expensive) was of fixing you fuel burning woes would be getting a set of hubs you could unlock and a shiftable transfer case.
I would honestly just go buy a cheap gas saver. Thats what I did. My trooper gets around 15-16 mpg and I got a 93 saturn sl2 and I get 35 mpg. What a huge diffrence this makes. And Insurance only went up about $30 a month.As right I have had the car for almost 2 months and it has almost paid its self off in what I have saved. Going to work when I am workn and not laid off cost was about 130. In the saturn it was around like $45 or something each week. And you can buy a saturn like this for under 1k on ebay most of the time in decent shape. They dont really rust out :0)
Thats what I plan on doing, I didnt want a little 4 cyl honda or anything because I didnt want a rice burner and I thought id have all this power with the v8 but its not like I can use it, I have to obey the speed limit ya know. One of my buddys let me drive his 4 cyl prelude the other day with just a muffler and a cold air intake and it really suprised me how well it went and he said "I get 35 miles a gallon" so when I get a job that will be the thing I look into getting.
My saturn is stock, and that thing really has some pickup. I was really impressed because the light weight etc it gets up and goes. The problem I have is I have always owned trucks and suv's. This is really like my 2nd car I have ever owned. I just dont like them in the winter thats why I kept my suv. But to be honest I drive the car and have only driven the suv like 8 times now since I have had the car for almost 2 months.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
469
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
850
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
8K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
blaze383
Banned
blaze383
Marion, North Carolina
VOA_NIGHTMARE
audiobaun
    May 19, 2024
    May 19, 2024
