Jbl...phd....cdt
I'm telling you, the clear winner is PHD. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I really like the fb series, if you have a ton of mounting depth, the fb pros might be a better idea. For only $30 more the midbass gain is insane, with great clarity on the top end still.
CDT's MX Designs sets are priced lower than other well known brands, feature-for-feature. They are the only brand with a wide assortment of options to make a 2-way set into a 3-way by simply adding 1 pair of speakers and changing some switches. whitedragon, if you have hands on experience with any of the new products CDT has released in the last 2 years, of which there are many, I would like to hear your feedback. I will forward constructive criticism to the owner of the company.
Really liking the phd 6.1 pros. Would a ppi 900.4 amp be enough to run them? Also with a clarion cz702 or 80prs. Not sure what HU but the substage will be a single sa-8 pushed by a mono amp around 600-750 watts.
Okay thanks. I heard the cz702 has a gloss finish, so its hard to read during the daytime? If thats the case id go with the 80prs. Does the 80 come with the mic or do i need to buy that seperate?
It comes with an autotune mic, and a bluetooth mic.
Well due to recent bills, I cannot spend the 300-350 anymore. I can only budget in around 200-250 for the front stage. Keep in mind I still need to buy the 80prs, amp kit, amps and subs.
Looks to be down to the JBL MS62c or IDs or HATs. Unless Im missing a component set I should look into. Im running passive because I know nothing about active and my tuning (crossover points, slope, etc) skills are not there yet. Any new help will be appreciated.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
Hunter88
Hunter88
Indiana
Ge_off_me
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
