jbl 1200.1 hook-up
Correct me if I'm wrong but the JBL 1200.1 has one mono output, correct? Assuming so, 2 8 ohm subs wired in parallel will create a 2 ohm load. Also (again correct me if I'm wrong) 2 DVC subs wired in series would create a 2 ohm load on that amp.
no, 2 8 ohm subs create a 4 ohm load, and 2 dvc subs @ 4 ohms per coil can only be wired at a 4ohm or 1 ohm, and yes that amp is stable at 2 ohms
snapnakk--on the jbl 1200.1
there are two sets of speaker outputs
one is a copy cat of the other for ease
of speaker instlation . you can wire
a 2 ohm sub on each speaker channel
and each sub would get 600 watts( per sub)
for a total of 1200 watts.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
Snapnakk
Snapnakk
MN
donaldlovescara
    May 18, 2024
    May 16, 2024
